Ana içeriğe geç
Hamilton Beach 70740 Power Cord Replacement
Neye ihtiyacın var
    1. Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: adım 1, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: adım 1, 2 resimden 2.
      • Turn the bowl counterclockwise and lift.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Power Cord Replacement, Base: adım 2, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement, Base: adım 2, 2 resimden 2.
      • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
      • Pull suction cups straight out.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Power Cord Replacement: adım 3, 3 resimden 1. Hamilton Beach 70740 Power Cord Replacement: adım 3, 3 resimden 2. Hamilton Beach 70740 Power Cord Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      Heavy-Duty Spudger
      • Remove rubber caps using the heavy duty spudger.
      • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
      • Pull base straight out.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Power Cord Replacement, Power Cord: adım 4, 3 resimden 1. Hamilton Beach 70740 Power Cord Replacement, Power Cord: adım 4, 3 resimden 2. Hamilton Beach 70740 Power Cord Replacement, Power Cord: adım 4, 3 resimden 3.
      • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
      • From the open base pull the motor straight out.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Power Cord Replacement: adım 5, 1 resimden 1.
      • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor and then rewire the new power cord to the motor.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 70740 Power Cord Replacement: adım 6, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement: adım 6, 2 resimden 2.
      • Remove the two 12 mm screws using the #2 Phillips head screwdriver.
      • Remove plastic piece.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 70740 Power Cord Replacement: adım 7, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement: adım 7, 2 resimden 2.
      • Remove the three 12 mm screws using the #2 Phillips head screwdriver.
      • Remove the plastic piece by pulling straight up.
      FixBot'a Sor
      Yorum Ekle
    5. Hamilton Beach 70740 Power Cord Replacement: adım 8, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement: adım 8, 2 resimden 2.
      • Remove the power cord from the ground by removing the solder with the soldering tool.
      • Solder the new ground from the new power cord.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Travis Williams
552 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-4, Blackwell Spring 2017 USF Tampa, Team 17-4, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 1,085
