Giriş
Replacement of the power cord. Make sure to keep the processor unplugged until finished with replacement.
Neye ihtiyacın var
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
From the open base pull the motor straight out.
Bir başkası bu kılavuzu tamamladı.
