Ana içeriğe geç
Hamilton G5 Inspiratory Valve Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Hamilton G5 Inspiratory Valve Replacement, Rail: adım 1, 1 resimden 1.
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Inspiratory Valve Replacement: adım 2, 1 resimden 1.
    • Remove the Rail (B).
  3. Hamilton G5 Inspiratory Valve Replacement: adım 3, 1 resimden 1.
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Inspiratory Valve Replacement, Main Cover: adım 5, 1 resimden 1.
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Inspiratory Valve Replacement, Safety Valve Block: adım 7, 1 resimden 1.
    • Remove Safety Valve Block
    • 1. Disconnect the cable from the Ambient Valve Solenoid
    • 2. Disconnect the Shaped Hose (A)
    • 3. Remove the 2 Hex Allen Screws (B)
    • 4. Remove the Safety Valve Block
    • To remove Ambient Valve Solenoid: Unscrew the Ambient Valve Solenoid (C) form the Safety Valve Block
  6. Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: adım 8, 2 resimden 1. Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: adım 8, 2 resimden 2.
    • Removing the Inspiration Valve
    • 1. Disconnect the tubing and cables form the Inspiration Valve
    • 3. Remove 2 Hex Allen screws (B) M5x60
    • 4. Move the Inspiration Valve forward and then up
    • 5. Remove the Inspiration Valve
Sonuç
William
145 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G25, Paton Spring 2020 Cal Poly, Team S7-G25, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G25
6 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
wow great manual! very helpful and informative!
William - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 257
