Ana içeriğe geç
Hamilton G5 Internal and Extended Battery Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Hamilton G5 Internal and Extended Battery Replacement, Rail: adım 1, 1 resimden 1.
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
    FixBot'a Sor
    Yorum Ekle
  2. Hamilton G5 Internal and Extended Battery Replacement: adım 2, 1 resimden 1.
    • Remove the Rail (B).
    FixBot'a Sor
    Yorum Ekle
  3. Hamilton G5 Internal and Extended Battery Replacement: adım 3, 1 resimden 1.
    • The Standoff Brackets (C) remain with the Main Cover.
    FixBot'a Sor
    Yorum Ekle
    • Place aside in a safe location.
    FixBot'a Sor
    Yorum Ekle
  4. Hamilton G5 Internal and Extended Battery Replacement, Main Cover: adım 5, 1 resimden 1.
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
    FixBot'a Sor
    Yorum Ekle
    FixBot'a Sor
    Yorum Ekle
  5. Hamilton G5 Internal and Extended Battery Replacement, Internal and Extended Battery: adım 7, 1 resimden 1.
    • Unscrew the 4 Hex Allen M4x8 screws (A), 2 on each side of the cover.
    • Lower the Front Cover (B) to remove it.
    • Disconnect the Alarm Status Display Connector (D) and set aside.
    FixBot'a Sor
    Yorum Ekle
  6. Hamilton G5 Internal and Extended Battery Replacement: adım 8, 1 resimden 1.
    • Remove the 8 Hex Allen screws M4x8 (A) located on the side of the ventilator.
    • Locate internal battery (B) and slide it out.
    • Disconnect battery cable (C) and fully remove battery assembly.
    FixBot'a Sor
    Yorum Ekle
  7. Hamilton G5 Internal and Extended Battery Replacement: adım 9, 1 resimden 1.
    • Remove 2 Hex Nuts, Washers, (D) and Cross Bar (E) from assembly.
    • Slide internal battery out from battery assembly.
    FixBot'a Sor
    Yorum Ekle
  8. Hamilton G5 Internal and Extended Battery Replacement: adım 10, 1 resimden 1.
    • Extended Battery
    • Depress battery latch on right side (follow yellow arrow in image).
    • Slide the battery out of bracket to remove.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Heidi Silk
139 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G25, Paton Spring 2020 Cal Poly, Team S7-G25, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G25
6 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 1,352
