Ana içeriğe geç
Hamilton G5 Nebulizer Valve Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Hamilton G5 Nebulizer Valve Replacement, Rail: adım 1, 1 resimden 1.
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Nebulizer Valve Replacement: adım 2, 1 resimden 1.
    • Remove the Rail (B).
  3. Hamilton G5 Nebulizer Valve Replacement: adım 3, 1 resimden 1.
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Nebulizer Valve Replacement, Main Cover: adım 5, 1 resimden 1.
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Nebulizer Valve Replacement, Nebulizer Valve: adım 7, 1 resimden 1.
    • After the rail and main cover are taken off, remove the dark blue tubing connected to the nebulizer, pictured here.
  6. Hamilton G5 Nebulizer Valve Replacement: adım 8, 1 resimden 1.
    • Remove the two phillips screws labeled A from the Nebulizer valve.
  7. Hamilton G5 Nebulizer Valve Replacement: adım 9, 1 resimden 1.
    • Remove the nebulizer valve parts.
    • The Nebulizer Valve parts are:B. Straight fitting
    • C. Front Nozzle fitting
    • D. Elbow fitting
    • E. Mounting bracket
    • F. Hex Allen screw for attaching the bracket to the Safety Valve Block
Sonuç
Cole Korchek
133 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G25, Paton Spring 2020 Cal Poly, Team S7-G25, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G25
6 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 195
