Ana içeriğe geç
Hamilton G5 Ventilation Unit Motherboard Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Hamilton G5 Ventilation Unit Motherboard Replacement, Rail: adım 1, 1 resimden 1.
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Ventilation Unit Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the Rail (B).
  3. Hamilton G5 Ventilation Unit Motherboard Replacement: adım 3, 1 resimden 1.
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Ventilation Unit Motherboard Replacement, Main Cover: adım 5, 1 resimden 1.
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Ventilation Unit Motherboard Replacement, Ventilation Unit Motherboard: adım 7, 1 resimden 1.
    • First, we need to remove the ESM module. It is connected to 2 connector sockets. Disconnect and remove.
    • Take out the Ventilation Real-time Controller (VRC) SW chip
  6. Hamilton G5 Ventilation Unit Motherboard Replacement: adım 9, 1 resimden 1.
    • Install the ESM Module, by connecting the connectors (A), and the VRC SW chip on the new board.
  7. Hamilton G5 Ventilation Unit Motherboard Replacement: adım 10, 1 resimden 1.
    • Disconnect all cables and connections from the board to the unit.
  8. Hamilton G5 Ventilation Unit Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the three Hex screws (B).
  9. Hamilton G5 Ventilation Unit Motherboard Replacement: adım 12, 1 resimden 1.
    • Move the motherboard out then up away from the ventilation unit (C).
Sonuç
Dane Dormedy
349 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G25, Paton Spring 2020 Cal Poly, Team S7-G25, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G25
6 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 262
