Ana içeriğe geç
Hamilton Galileo Ventilator Power Supply Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Hamilton Galileo Ventilator Power Supply Replacement, Opening the Column in the Hamilton Galileo: adım 1, 1 resimden 1.
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Hamilton Galileo Ventilator Power Supply Replacement: adım 3, 1 resimden 1.
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Hamilton Galileo Ventilator Power Supply Replacement: adım 4, 2 resimden 1. Hamilton Galileo Ventilator Power Supply Replacement: adım 4, 2 resimden 2.
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
  4. Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: adım 6, 2 resimden 1. Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: adım 6, 2 resimden 2.
    • Remove all cables connecting power supply to GALILEO.
    • To remove the main power connector, squeeze on the two points indicated in the second picture.
    • Remove the rear cover and place it on a suitable surface.
  5. Hamilton Galileo Ventilator Power Supply Replacement: adım 8, 1 resimden 1.
    • Unscrew the retaining strip securing the power supply in its housing.
  6. Hamilton Galileo Ventilator Power Supply Replacement: adım 9, 1 resimden 1.
    • Slide the power supply out from its housing.
  7. Hamilton Galileo Ventilator Power Supply Replacement: adım 10, 2 resimden 1. Hamilton Galileo Ventilator Power Supply Replacement: adım 10, 2 resimden 2.
    • To install the new power supply, simply do steps 5-2 in reverse.
    • Make sure the security clamp (shown in picture) is tight before reinstalling power supply.
    • Perform the internal voltage test linked here: page 7-5 of Section 7.3, Checking voltages.
    • If this test is not successful, it is likely that there is a loose connection somewhere between the internal power supply and the printed circuit boards. Check the wires to make sure they are securely fastened.
    • When the above test is successful, continue with the tests in the following sections:
    • 1) Section7, Checking hardware, voltages, and interface
    • 2) Either: Section 9, Running Original Upgrade 1 test software OR Section 10, Running Upgrade 2 test software
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ian Van Sciver
332 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G26, Paton Spring 2020 Cal Poly, Team S7-G26, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G26
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 665
