Ana içeriğe geç
Handle Replacement on Patagonia Freewheeler/Freightliner Luggage
Neye ihtiyacın var
  1. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: adım 1, 3 resimden 1. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: adım 1, 3 resimden 2. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: adım 1, 3 resimden 3.
    • Open the zipper at the base of the bag, then open the zipper in the compartment liner to expose the handle mechanisms.
    • All metal bars should be straight and plastic housings should be intact. Replacing the handle won't work if the metal bars or handle housings are damaged or bent.
    • If there is a possibility that the handle is sticking but not damaged, try lubricating it first.
  2. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the screws and clips: adım 2, 3 resimden 1. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the screws and clips: adım 2, 3 resimden 2. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the screws and clips: adım 2, 3 resimden 3.
    • Use a Phillips PH1 screwdriver to remove the four screws at the top handle bracket.
    • Then remove the two black plastic retaining clips that were kept in place by the red screws.
    • Be careful not to lose these pieces! Put them somewhere safe and accessible, they'll be reused later on.
  3. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the damaged handle: adım 3, 3 resimden 1. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the damaged handle: adım 3, 3 resimden 2. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the damaged handle: adım 3, 3 resimden 3.
    • Press the handle release button to retract the toggle buttons on the handle.
    • If the toggle buttons won't retract, use a pointed object (like a screwdriver) to depress the buttons into the handle housing manually.
    • Pull the handle up and out of the handle housing. Use a repeated side-to-side movement to free the black plastic sleeves on the bottom portion of the handle.
    • Discard the damaged handle responsibly.
  4. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Insert the new handle: adım 4, 3 resimden 1. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Insert the new handle: adım 4, 3 resimden 2. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Insert the new handle: adım 4, 3 resimden 3.
    • While holding the release button on the top, use a repeated up-and-down movement to insert the new handle into the handle housing.
    • Replace the retaining brackets and screws to the original positions.
  5. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Test the handle functionality: adım 5, 3 resimden 1. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Test the handle functionality: adım 5, 3 resimden 2. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Test the handle functionality: adım 5, 3 resimden 3.
    • Test that the handle works properly. Move the handle into all positions and ensure it locks securely at each position:
    • Fully extended
    • Middle position (medium and small bags only)
    • Fully collapsed into the handle housing
    • The toggle buttons should move freely when the handle release button is pressed.
    • If the toggles function but need some TLC, see Stuck Luggage Handle Lubrication.
    • Close the interior liner zipper and main zipper compartments.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
89.739 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.429 adet Kılavuz yazıldı
2 Yorum
I depressed the pins. It worked once or twice. But now, I have to depress the pins every time to get the handle to work OR even with the pins depressed it will still not retract or if retracted it will still not open.
What is the solution?
I love this suitcase otherwise, but the handle has always been tricky needing just the right angle on the way in and having to jiggle it to get it out.
Help Patagonia!
Sharon - Yanıt
Hi Sharon,
The solution to depress the pins was meant to be a temporary solution when your handle is stuck in the extended position. Unfortunately, it means that your handle needs to be replaced as the handle trigger mechanism and pins are not functioning properly. Contact Patagonia for a new handle. You can either call us and we will can ship you a new one and you can replace yourself, or you can go to a Patagonia Retail Store and get a new handle there, afterwhich you can use the handing guidelines for replacement. Please visit our website for phone number and to locate a store near you. Copy and paste this URL in your search engine bar or click on the link.
http://www.patagonia.com/us/patagonia.go...
Marty Chapman -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 44
Son 30 gün: 109
Her zaman: 32,856
