Ana içeriğe geç
Handle Replacement on a Patagonia Black Hole® Wheeled Duffel
Neye ihtiyacın var
  1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Access the handle assembly: adım 1, 3 resimden 1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Access the handle assembly: adım 1, 3 resimden 2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Access the handle assembly: adım 1, 3 resimden 3.
    • Starting with an empty duffel, unzip and open the main zipper compartment.
    • Then unzip the zipper on the inside liner to access the handle assembly.
    • Patagonia Repair Tech Tip: To increase visibility, push the liner fabric out of the way and use an extra light source like a flashlight or headlamp.
  2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove the internal screws: adım 2, 3 resimden 1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove the internal screws: adım 2, 3 resimden 2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove the internal screws: adım 2, 3 resimden 3.
    • Locate the top and bottom handle brackets.
    • Use a Phillips PH2 screwdriver to remove the seven screws securing the handle brackets:
    • Five screws from the top handle bracket
    • Two screws from the bottom handle bracket
    • Set the screws aside to be reused.
  3. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove the top handle bracket: adım 3, 1 resimden 1.
    • Remove the top handle bracket and set it aside. Don't discard it.
  4. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove the handle from the duffel: adım 4, 3 resimden 1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove the handle from the duffel: adım 4, 3 resimden 2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove the handle from the duffel: adım 4, 3 resimden 3.
    • Remove the handle from the duffel by pulling the entire handle assembly (including the plastic housing) away from the duffel body.
    • Push the duffel fabric inward, away from the plastic handle housing, to separate it from the duffel.
    • Once the plastic housing is detached from the duffel, the handle can be pulled out completely.
    • Discard the damaged handle responsibly.
  5. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Install the new handle: adım 5, 3 resimden 1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Install the new handle: adım 5, 3 resimden 2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Install the new handle: adım 5, 3 resimden 3.
    • Insert the new handle into the duffel. Both posts of the handle should slide securely into the bottom handle bracket.
    • Align the screw posts on the plastic housing with the holes at the top of the duffel.
    • The handle is fully inserted when the plastic housing is flush with the duffel body.
  6. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Secure the handle bottom: adım 6, 1 resimden 1.
    • Once the new handle is in place, return to the inside of the duffel and reinstall the screws into the bottom handle bracket.
    • Gently hand‑tighten the screws to avoid stripping the screw wells.
  7. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Reinstall the top handle bracket: adım 7, 3 resimden 1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Reinstall the top handle bracket: adım 7, 3 resimden 2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Reinstall the top handle bracket: adım 7, 3 resimden 3.
    • Place the top handle bracket back into place on top of the handle housing and ensure that the screw holes of the handle bracket align with the screw posts of the handle housing.
    • Use a Phillips PH2 screwdriver to install the five screws securing the top handle bracket while holding the bracket in place.
    • Follow the sequential order noted in the third photo.
    • Lift the handle bracket at each screw location to ensure it's securely in place.
  8. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Test the handle functionality: adım 8, 3 resimden 1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Test the handle functionality: adım 8, 3 resimden 2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Test the handle functionality: adım 8, 3 resimden 3.
    • Test that the handle works properly. Move the handle into all positions and ensure it locks securely at each position:
    • Fully extended
    • Middle position (medium and small duffels only)
    • Fully collapsed into the handle housing
  9. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Close the duffel: adım 9, 3 resimden 1. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Close the duffel: adım 9, 3 resimden 2. Handle Replacement on a Patagonia Black Hole® Wheeled Duffel, Close the duffel: adım 9, 3 resimden 3.
    • Zip the inside liner and the main compartment to restore the duffel for use.
Bitiş Çizgisi
Marty Chapman
432 İtibar
3 adet Kılavuz yazıldı
Ekip
Patagonia Patagonia üyesi
Community
17 Üyeler
74 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 95
Son 30 gün: 173
Her zaman: 1,692
