Ana içeriğe geç
Handset Microphone Replacement
Neye ihtiyacın var
  1. Handset Microphone Replacement, Handset: adım 1, 1 resimden 1.
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  2. Handset Microphone Replacement: adım 2, 2 resimden 1. Handset Microphone Replacement: adım 2, 2 resimden 2.
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  3. Handset Microphone Replacement: adım 3, 2 resimden 1. Handset Microphone Replacement: adım 3, 2 resimden 2.
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
  4. Handset Microphone Replacement, Handset Microphone: adım 4, 2 resimden 1. Handset Microphone Replacement, Handset Microphone: adım 4, 2 resimden 2.
    • After disassembling the handset, you will see the inner components of the handset.
    • Locate the rubber part towards the very bottom of the handset. This is the microphone with protective rubber cover.
    • Remove the protective rubber cover. This may require a spudger.
    • The microphone is exposed upon removal of the protective rubber cover. Avoid contact with water.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Han Shih
361 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G3
4 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 417
