Ana içeriğe geç
Handset Speaker Replacement
Neye ihtiyacın var
  1. Handset Speaker Replacement, Handset: adım 1, 1 resimden 1.
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  2. Handset Speaker Replacement: adım 2, 2 resimden 1. Handset Speaker Replacement: adım 2, 2 resimden 2.
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  3. Handset Speaker Replacement: adım 3, 2 resimden 1. Handset Speaker Replacement: adım 3, 2 resimden 2.
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
  4. Handset Speaker Replacement, Handset Speaker: adım 4, 1 resimden 1.
    • After disassembling the handset, you will see a circular component at the top section of the handset. This is your speaker.
    • Use a screwdriver to remove the three 7mm Phillips #0 screws holding the speaker in place.
  5. Handset Speaker Replacement: adım 5, 1 resimden 1.
    • Gently pull out the speaker and inspect it.
    • Determine if the handset speaker is damaged and needs replaced. Replacement requires soldering.
    • Finish removing a faulty speaker by cutting the two wires connecting it to the circuit board.
  6. Handset Speaker Replacement: adım 6, 1 resimden 1.
    • Solder the replacement speaker in the circuit board. For information on how-to-solder check iFixit's Solder and Desolder Guide by clicking the blue link below.
Sonuç
Han Shih
361 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G3
4 Üyeler
17 adet Kılavuz yazıldı
Bir Yorum
What shall I look for speaker is not working?
naila ilyas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 701
