Ana içeriğe geç
Handspring Visor Deluxe PDA Touch Screen Replacement
Neye ihtiyacın var
  1. Handspring Visor Deluxe PDA Touch Screen Replacement, Outside cover and stylus: adım 1, 2 resimden 1. Handspring Visor Deluxe PDA Touch Screen Replacement, Outside cover and stylus: adım 1, 2 resimden 2.
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 2, 3 resimden 1. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 2, 3 resimden 2. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 2, 3 resimden 3.
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 3, 3 resimden 1. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 3, 3 resimden 2. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 3, 3 resimden 3.
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Touch Screen Replacement, Batteries: adım 4, 2 resimden 1. Handspring Visor Deluxe PDA Touch Screen Replacement, Batteries: adım 4, 2 resimden 2.
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 5, 1 resimden 1.
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Touch Screen Replacement, Back Cover: adım 6, 1 resimden 1.
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 7, 3 resimden 1. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 7, 3 resimden 2. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 7, 3 resimden 3.
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 8, 3 resimden 1. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 8, 3 resimden 2. Handspring Visor Deluxe PDA Touch Screen Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: adım 9, 3 resimden 1. Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: adım 9, 3 resimden 2. Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: adım 9, 3 resimden 3.
    • Release the latch in bottom right corner of the touchscreen.
    • Use the spudger (if needed) to pry the screen from the front case.
Sonuç
David Faltemier
19 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-2, Regan SU 2012 Cal Poly, Team 1-2, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 852
