Ana içeriğe geç
Handspring Visor Edge Battery Replacement
Neye ihtiyacın var
  1. Handspring Visor Edge Battery Replacement, Flip Cover: adım 1, 2 resimden 1. Handspring Visor Edge Battery Replacement, Flip Cover: adım 1, 2 resimden 2.
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Battery Replacement, Back Panel: adım 2, 1 resimden 1.
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Battery Replacement: adım 3, 1 resimden 1.
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Battery Replacement: adım 4, 2 resimden 1. Handspring Visor Edge Battery Replacement: adım 4, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Battery Replacement: adım 5, 2 resimden 1. Handspring Visor Edge Battery Replacement: adım 5, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Battery Replacement: adım 6, 1 resimden 1.
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Battery Replacement, Battery: adım 7, 1 resimden 1.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Battery Replacement: adım 8, 2 resimden 1. Handspring Visor Edge Battery Replacement: adım 8, 2 resimden 2.
    • Gently use your finger or tweezers to push the brown lock away from the side of the circuit board that is holding the ribbon cable.
    • Remove the ribbon cable with tweezers.
  9. Handspring Visor Edge Battery Replacement: adım 9, 1 resimden 1.
    • Using the tweezers, pull back the ribbon cable on the top of the device.
    • Pull at the white part of the ribbon to avoid tearing.
  10. Handspring Visor Edge Battery Replacement: adım 10, 1 resimden 1.
    • Using the same technique as with the other ribbons, locate and disconnect the ribbon cable above the battery pack.
  11. Handspring Visor Edge Battery Replacement: adım 11, 1 resimden 1.
    • All the ribbon cables should be disconnected from the mother board.
    • Remove the four 3.6 mm Phillips #00 screws located at each corner of the device.
  12. Handspring Visor Edge Battery Replacement: adım 12, 2 resimden 1. Handspring Visor Edge Battery Replacement: adım 12, 2 resimden 2.
    • Carefully separate the circuit board and the screen. (Be careful of soldered wires when separating)
    • Be careful not to break the soldered wires that connects the circuit board to the battery pack.
    • Disconnect the wire that connects the battery pack to the motherboard using tweezers.
  13. Handspring Visor Edge Battery Replacement: adım 13, 2 resimden 1. Handspring Visor Edge Battery Replacement: adım 13, 2 resimden 2.
    • Wedge the spudger under the battery to pry it apart from the adhesive.
Sonuç
Christian Valoria
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G28
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 3,141
