Ana içeriğe geç
Handspring Visor Edge Button Board Replacement
Neye ihtiyacın var
  1. Handspring Visor Edge Button Board Replacement, Flip Cover: adım 1, 2 resimden 1. Handspring Visor Edge Button Board Replacement, Flip Cover: adım 1, 2 resimden 2.
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Button Board Replacement, Back Panel: adım 2, 1 resimden 1.
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Button Board Replacement: adım 3, 1 resimden 1.
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Button Board Replacement: adım 4, 2 resimden 1. Handspring Visor Edge Button Board Replacement: adım 4, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Button Board Replacement: adım 5, 2 resimden 1. Handspring Visor Edge Button Board Replacement: adım 5, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Button Board Replacement: adım 6, 1 resimden 1.
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Button Board Replacement, Button Board: adım 7, 1 resimden 1.
    • Pull off front cover gently.
  8. Handspring Visor Edge Button Board Replacement: adım 8, 1 resimden 1.
    • Remove buttons by hand, they should come off easily.
Sonuç
Nick Lazarakis
331 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G28
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 763
