Ana içeriğe geç
Handspring Visor Edge Flip Cover Spring Replacement
Neye ihtiyacın var
  1. Handspring Visor Edge Flip Cover Spring Replacement, Flip Cover: adım 1, 2 resimden 1. Handspring Visor Edge Flip Cover Spring Replacement, Flip Cover: adım 1, 2 resimden 2.
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Flip Cover Spring Replacement, Flip Cover Spring: adım 2, 1 resimden 1.
    • Once flip cover is removed, turn over and remove the four 3.9 mm screws connecting the hinge.
  3. Handspring Visor Edge Flip Cover Spring Replacement: adım 3, 2 resimden 1. Handspring Visor Edge Flip Cover Spring Replacement: adım 3, 2 resimden 2.
    • Gently pull away the plastic hinge from the cover.
    • Be careful to pull out evenly and not bend the plastic, as it can crack.The spring may also shoot out if it is not pulled out evenly.
  4. Handspring Visor Edge Flip Cover Spring Replacement: adım 4, 1 resimden 1.
    • Turn the hinge piece on its side or use a screwdriver to pull out the spring.
    • Reinsert new spring.
Sonuç
Blaize Steiger
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G28
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,103
