Ana içeriğe geç
Handspring Visor Edge Screen Replacement
Neye ihtiyacın var
  1. Handspring Visor Edge Screen Replacement, Flip Cover: adım 1, 2 resimden 1. Handspring Visor Edge Screen Replacement, Flip Cover: adım 1, 2 resimden 2.
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Screen Replacement, Back Panel: adım 2, 1 resimden 1.
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Screen Replacement: adım 3, 1 resimden 1.
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Screen Replacement: adım 4, 2 resimden 1. Handspring Visor Edge Screen Replacement: adım 4, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Screen Replacement: adım 5, 2 resimden 1. Handspring Visor Edge Screen Replacement: adım 5, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Screen Replacement: adım 6, 1 resimden 1.
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Screen Replacement, Screen: adım 7, 1 resimden 1.
    • Place the PDA front face up.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Screen Replacement: adım 8, 2 resimden 1. Handspring Visor Edge Screen Replacement: adım 8, 2 resimden 2.
    • Flip over the PDA.
    • Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
  9. Handspring Visor Edge Screen Replacement: adım 9, 2 resimden 1. Handspring Visor Edge Screen Replacement: adım 9, 2 resimden 2.
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side. The screen will pop off.
Sonuç
Christian Valoria
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G28
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 1,549
