Ana içeriğe geç
Handspring Visor Edge Speaker Replacement
Neye ihtiyacın var
  1. Handspring Visor Edge Speaker Replacement, Flip Cover: adım 1, 2 resimden 1. Handspring Visor Edge Speaker Replacement, Flip Cover: adım 1, 2 resimden 2.
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Speaker Replacement, Back Panel: adım 2, 1 resimden 1.
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Speaker Replacement: adım 4, 2 resimden 1. Handspring Visor Edge Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Speaker Replacement: adım 5, 2 resimden 1. Handspring Visor Edge Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Speaker Replacement: adım 6, 1 resimden 1.
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Speaker Replacement, Speaker: adım 7, 1 resimden 1.
    • Gently pull off front cover.
  8. Handspring Visor Edge Speaker Replacement: adım 8, 1 resimden 1.
    • Gently remove buttons by hand.
  9. Handspring Visor Edge Speaker Replacement: adım 9, 1 resimden 1.
    • Pull off button board.
    • (The button board is located underneath the buttons).
  10. Handspring Visor Edge Speaker Replacement: adım 10, 1 resimden 1.
    • Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
    • Pull in the same direction as the individual wires are running and make sure to evenly on the full width of the cable so that no individual wires are overly strained.
Sonuç
Nick Lazarakis
331 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G28
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 803
