Ana içeriğe geç
Hannspree Hannspad SN1AT71 Back Panel Replacement
Neye ihtiyacın var
  1. Hannspree Hannspad SN1AT71 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Back Panel Replacement: adım 2, 2 resimden 1. Hannspree Hannspad SN1AT71 Back Panel Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Back Panel Replacement: adım 3, 1 resimden 1.
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Back Panel Replacement: adım 4, 2 resimden 1. Hannspree Hannspad SN1AT71 Back Panel Replacement: adım 4, 2 resimden 2.
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Back Panel Replacement: adım 5, 2 resimden 1. Hannspree Hannspad SN1AT71 Back Panel Replacement: adım 5, 2 resimden 2.
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
matthew vandeventer
950 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 16
Her zaman: 2,380
