Ana içeriğe geç
Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement
Neye ihtiyacın var
  1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 2, 2 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 3, 1 resimden 1.
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 4, 2 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 4, 2 resimden 2.
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 5, 2 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 5, 2 resimden 2.
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: adım 6, 2 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 7, 3 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 7, 3 resimden 2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 7, 3 resimden 3.
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 8, 3 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 8, 3 resimden 2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 8, 3 resimden 3.
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 9, 3 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 9, 3 resimden 2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 9, 3 resimden 3.
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: adım 10, 2 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: adım 10, 2 resimden 2.
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
  11. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 11, 3 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 11, 3 resimden 2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 11, 3 resimden 3.
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
  12. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 12, 3 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 12, 3 resimden 2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 12, 3 resimden 3.
    • Pull the cameras out of their resting places in a straight upward motion.
  13. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: adım 13, 3 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: adım 13, 3 resimden 2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: adım 13, 3 resimden 3.
    • Identify the speakers.
    • Use a pair of tweezers to peel the adhesive tape holding the speaker wires down.
  14. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 14, 3 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 14, 3 resimden 2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 14, 3 resimden 3.
    • Desolder the red and black wire to the left and the right of the ZIF connector.
    • Remember the placement of both wires.
    • Both the soldering iron and the wires will be hot.
  15. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 15, 2 resimden 1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: adım 15, 2 resimden 2.
    • Remove the right and left speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
matthew vandeventer
950 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 423
