Ana içeriğe geç
Hannspree SN12E2 Hard Drive Access Door Replacement
Neye ihtiyacın var
  1. Hannspree SN12E2 Hard Drive Access Door Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Hard Drive Access Door Replacement: adım 2, 1 resimden 1.
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Hard Drive Access Door Replacement: adım 3, 3 resimden 1. Hannspree SN12E2 Hard Drive Access Door Replacement: adım 3, 3 resimden 2. Hannspree SN12E2 Hard Drive Access Door Replacement: adım 3, 3 resimden 3.
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Hard Drive Access Door Replacement, Hard Drive Access Door: adım 4, 1 resimden 1.
    • Remove the three 3mm Phillips #0 screws.
  5. Hannspree SN12E2 Hard Drive Access Door Replacement: adım 5, 1 resimden 1.
    • Gently pull on the access panel to remove it.
Sonuç
Brianna Johnson
422 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 UMass Dartmouth, Team S2-G2, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 89
