Ana içeriğe geç
Hannspree SN12E2 Hard Drive Replacement
Neye ihtiyacın var
  1. Hannspree SN12E2 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Hard Drive Replacement: adım 3, 3 resimden 1. Hannspree SN12E2 Hard Drive Replacement: adım 3, 3 resimden 2. Hannspree SN12E2 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Hard Drive Replacement, Hard Drive Access Door: adım 4, 1 resimden 1.
    • Remove the three 3mm Phillips #0 screws.
  5. Hannspree SN12E2 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Gently pull on the access panel to remove it.
  6. Hannspree SN12E2 Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Remove the four 4mm Phillips #0 retaining screws.
    • The hard drive caddy is the large piece of metal with black circles.
  7. Hannspree SN12E2 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Next, lift up the hard drive and pull towards you. Lift up the end of the hard drive that is not plugged into the computer.
  8. Hannspree SN12E2 Hard Drive Replacement: adım 8, 2 resimden 1. Hannspree SN12E2 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Slide your hard drive out of the metal piece by unscrewing the sides.
Sonuç
Kyle Duby
193 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 UMass Dartmouth, Team S2-G2, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 173
