Ana içeriğe geç
Hannspree SN12E2 IO Board Replacement
Neye ihtiyacın var
  1. Hannspree SN12E2 IO Board Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 IO Board Replacement: adım 2, 1 resimden 1.
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 IO Board Replacement: adım 3, 3 resimden 1. Hannspree SN12E2 IO Board Replacement: adım 3, 3 resimden 2. Hannspree SN12E2 IO Board Replacement: adım 3, 3 resimden 3.
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 IO Board Replacement, Touchpad Plane/Keyboard: adım 4, 1 resimden 1.
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 IO Board Replacement: adım 5, 3 resimden 1. Hannspree SN12E2 IO Board Replacement: adım 5, 3 resimden 2. Hannspree SN12E2 IO Board Replacement: adım 5, 3 resimden 3.
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 IO Board Replacement: adım 6, 2 resimden 1. Hannspree SN12E2 IO Board Replacement: adım 6, 2 resimden 2.
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 IO Board Replacement: adım 7, 1 resimden 1.
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 IO Board Replacement, Hard Drive Access Door: adım 8, 1 resimden 1.
    • Remove the three 3mm Phillips #0 screws.
  9. Hannspree SN12E2 IO Board Replacement: adım 9, 1 resimden 1.
    • Gently pull on the access panel to remove it.
  10. Hannspree SN12E2 IO Board Replacement, Hard Drive: adım 10, 1 resimden 1.
    • Remove the four 4mm Phillips #0 retaining screws.
    • The hard drive caddy is the large piece of metal with black circles.
  11. Hannspree SN12E2 IO Board Replacement: adım 11, 1 resimden 1.
    • Next, lift up the hard drive and pull towards you. Lift up the end of the hard drive that is not plugged into the computer.
  12. Hannspree SN12E2 IO Board Replacement: adım 12, 2 resimden 1. Hannspree SN12E2 IO Board Replacement: adım 12, 2 resimden 2.
    • Slide your hard drive out of the metal piece by unscrewing the sides.
  13. Hannspree SN12E2 IO Board Replacement, IO Board: adım 13, 1 resimden 1.
    • Remove the three 3mm PH0 screws holding the IO board to the case.
  14. Hannspree SN12E2 IO Board Replacement: adım 14, 3 resimden 1. Hannspree SN12E2 IO Board Replacement: adım 14, 3 resimden 2. Hannspree SN12E2 IO Board Replacement: adım 14, 3 resimden 3.
    • Unplug the three JST connectors connecting the IO board to the motherboard.
    • For each connector, remove by gently pulling parallel to the connector housing until the connector becomes undone
    • When replacing the connectors ensure that they are oriented correctly. The housing is keyed to prevent the connectors from being plugged in backwards.
  15. Hannspree SN12E2 IO Board Replacement: adım 15, 1 resimden 1.
    • Remove IO Board by gently tilting it toward the outer edge of the case.
Sonuç
jacob
150 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 UMass Dartmouth, Team S2-G2, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 121
