Ana içeriğe geç
Hannspree SN12E2 RAM Replacement
Neye ihtiyacın var
  1. Hannspree SN12E2 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 RAM Replacement: adım 2, 1 resimden 1.
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 RAM Replacement: adım 3, 3 resimden 1. Hannspree SN12E2 RAM Replacement: adım 3, 3 resimden 2. Hannspree SN12E2 RAM Replacement: adım 3, 3 resimden 3.
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 RAM Replacement, RAM: adım 4, 2 resimden 1. Hannspree SN12E2 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Remove the RAM access door.
    • Remove the two 3mm screws using a Phillips #0 screwdriver.
    • Gently lift on the door out of place.
    • When replacing the door it should click into place. Ensure the alignment tabs are correctly seated and gently push until it clicks into place.
  5. Hannspree SN12E2 RAM Replacement: adım 5, 3 resimden 1. Hannspree SN12E2 RAM Replacement: adım 5, 3 resimden 2. Hannspree SN12E2 RAM Replacement: adım 5, 3 resimden 3.
    • Gently push outward on the two retaining clips, being careful not to damage the motherboard.
    • Lift up on the RAM until it makes a 35 degree angle with the board.
    • Remove the RAM by pulling away from the housing at 35 degrees.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim Chase
360 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 UMass Dartmouth, Team S2-G2, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 262
