Ana içeriğe geç
Hard / Factory Reset
Videoya Genel Bakış
  1. Hard / Factory Reset, Hard Reset - Method One:: adım 1, 3 resimden 1. Hard / Factory Reset, Hard Reset - Method One:: adım 1, 3 resimden 2. Hard / Factory Reset, Hard Reset - Method One:: adım 1, 3 resimden 3.
    • Switch off the phone.
    • Pres the Power button and when you feel a vibration release it and press and hold the Volume Up button.
    • From Boot mode menu select [Recovery mode] (use Volume Up for navigation and volume doun for OK).
    • Now you are in the known Android System recovery menu. Use again the Volume Up for navigation and the Volume Down for OK and select one by one: wipe data/factory reset - Yes -- delete all user data - reboot system now.
    • Tis will reboot the device and will restore to its default settings.
    FixBot'a Sor
    Yorum Ekle
  2. Hard / Factory Reset, Factory Reset - Method Two: adım 2, 3 resimden 1. Hard / Factory Reset, Factory Reset - Method Two: adım 2, 3 resimden 2. Hard / Factory Reset, Factory Reset - Method Two: adım 2, 3 resimden 3.
    • Press the Power button and wen you fill the vibration, release the Power button and press and hold the Volume Down button.
    • Now the device is in Factory mode. Use the Volume Up/Down buttons for movement and the Power button for OK and select Clear eMMC.
    • That's all. The phone will reboot and will be restored to a factory settings.
    • Did you do it successfully?
    FixBot'a Sor
    Yorum Ekle
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
ZFix
197.270 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
334 Üyeler
1.701 adet Kılavuz yazıldı
22Kılavuz Yorumları
great simple clear instructions - did exactly what you said - phone back up and running good as new! Thanks. M
Marty - Yanıt Paylaş
Thanks. The phone has reset.
melandart - Yanıt Paylaş
“eMMC is busy can't format, please retry”
What do we do?
richterrea - Yanıt Paylaş
Today I also met this message. How did you solve this problem? Thanks, Zoltan (HUN)
Zoltán Bocskai - Yanıt Paylaş
HI!, I did the “clear eMMc” method but still my MePop_V03 phone still stock on logo screen.
what should I do?
Please help me .thanks in advance God bless
Herbert Redondo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 69
Son 30 gün: 353
Her zaman: 56,236
