Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to back up your PS3’s data to a new drive before installing it.
  1. If you need to backup the data on your current hard drive, follow the instructions in this step. Otherwise, continue to the next step. On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
    • If you need to backup the data on your current hard drive, follow the instructions in this step. Otherwise, continue to the next step.
    • On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
    • Make sure it's formatted FAT32. The Playstation 3 backup utility will not recognize any other file system.
    • Connect your formatted hard drive to the Playstation 3 through a USB port and power the console up.
    • Navigate the XMB to the 'Settings' menu and select 'System Settings'
    • Select the 'Backup Utility' function to create a backup of your data - this can take up to 2 hours if you have a lot of data on the PS3.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,753
