Ana içeriğe geç
Hard Drive Replacement Guide
Neye ihtiyacın var
  1. Hard Drive Replacement Guide, Hard Drive: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to loosen the screws.
    • The screws are designed to remain in the panel.
    FixBot'a Sor
    Yorum Ekle
  2. Hard Drive Replacement Guide: adım 2, 3 resimden 1. Hard Drive Replacement Guide: adım 2, 3 resimden 2. Hard Drive Replacement Guide: adım 2, 3 resimden 3.
    • To open the panel, use a plastic opening tool or your finger.
    • If there is difficulty opening the panel, than the screws may not be lose enough.
    FixBot'a Sor
    Yorum Ekle
  3. Hard Drive Replacement Guide: adım 3, 2 resimden 1. Hard Drive Replacement Guide: adım 3, 2 resimden 2.
    • Use the Phillips #0 screwdriver to unscrew the two 5mm screws.
    • Remove the hard drive by using your fingers to pull firmly on the clear tab.
    FixBot'a Sor
    Yorum Ekle
  4. Hard Drive Replacement Guide: adım 4, 1 resimden 1.
    • You have successfully removed the hard drive from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Steven Park
420 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-5, Catania Spring 2016 UMass Dartmouth, Team 7-5, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,104
