Ana içeriğe geç
Hard Reset
  1. Hard Reset, Hard Reset: adım 1, 1 resimden 1.
    • With the phone powered off, press and hold the Talk/Send, End, and Power buttons (the 3 circled here) for about 3 seconds.
  2. Hard Reset: adım 2, 2 resimden 1. Hard Reset: adım 2, 2 resimden 2.
    • When the screen powers on, you will see an instructional message.
    • Press the volume up button to perform the hard reset.
    • The hard reset will erase all personal data on your device. If you would like to cancel the hard reset, press any other button.
  3. Hard Reset: adım 3, 1 resimden 1.
    • Your device will display this screen after a few seconds. Press the Volume Up button to boot your phone.
  4. Hard Reset: adım 4, 2 resimden 1. Hard Reset: adım 4, 2 resimden 2.
    • Your phone will display this screen. If you would like to import your SIM contacts now, tap "Import SIM contacts" and tap "Next". Otherwise, tap "Cancel".
Sonuç
You have just performed a hard reset on your HTC Fortress. All personal data on your phone has been deleted, and your phone is now back to its default settings.
7 farklı kişi bu kılavuzu tamamladı.
Lucas David
540 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-13, Maness Spring 2013 Cal Poly, Team 4-13, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G13
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
great information thanks.
regards
Jrubio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,510
