Ana içeriğe geç
Asus K52JC Laptop Hard Drive Replacement
Neye ihtiyacın var
  1. Asus K52JC Laptop Hard Drive Replacement, Power off and return the device: adım 1, 1 resimden 1.
    • First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
    • Next, remove the battery from the laptop.
    • In the picture, the battery is not installed.
  2. Asus K52JC Laptop Hard Drive Replacement, Remove the screws and open the cover: adım 2, 2 resimden 1. Asus K52JC Laptop Hard Drive Replacement, Remove the screws and open the cover: adım 2, 2 resimden 2.
    • Next, remove the 4 Phillips screws from the service door cover (circled in red).
    • In this photo, the screws have already been removed.
  3. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from it's location: adım 3, 2 resimden 1. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from it's location: adım 3, 2 resimden 2.
    • Remove the 4 screws circled in red in the photo.
    • Once the screws are removed, slide the hard drive to the right, with the help of the tab.
  4. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: adım 4, 3 resimden 1. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: adım 4, 3 resimden 2. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: adım 4, 3 resimden 3.
    • Remove the 4 screws located on the side of the support.
    • Then, remove the hard drive form its metallic support.
    • Finally, replace de hard drive with a new one or an SSD.
Sonuç
To reassemble your device, follow these steps in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Brendan
51.536 İtibar
3 adet Kılavuz yazıldı
3 Yorum
why do you do this?
Carl Jefferson - Yanıt
You can do this to replace a faulty hard-drive or replace it by a SSD to get better performance. So I did this to replace mine by a new one and I wrote this guide for other people who search how to do it. As you can see, very easy to do.
Brendan -
Amazing tutorial, thanks :)
Jérémy Martin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 1,520
