Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
The spark plugs are easy to spot on the left side of the motorcycle.
Carefully remove the spark plug wire. Do not pull on just the wire, squeeze the spark plug boot, and pull it together with the wire.
Use an 11/16" spark plug socket to unscrew the spark plug by turning in a counter-clockwise direction.
Remove the spark plug from the cylinder.
Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches (1.016mm).
Using your fingers, install the new spark plug into the socket, and hand tighten until firm.
Using a torque wrench, tighten the spark plug to the proper specification.
Reinstall your spark plug wire by pushing it firmly onto the new plug.
20 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Couldn't have made it any simpler
-awesome
- appreciated
Thank you so much for your posting. I'm 2k miles from my daughter who is teaching herself how to maintain her own bike. You site is immensely helpful and appreciated as much.
Says between 11 and 18 pounds in manuel
