Ana içeriğe geç
Harman Kardon Esquire Mini External Stand Replacement
Neye ihtiyacın var
  1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: adım 1, 1 resimden 1.
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Harman Kardon Esquire Mini External Stand  Replacement: adım 2, 1 resimden 1.
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
    FixBot'a Sor
    Yorum Ekle
  3. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: adım 3, 1 resimden 1.
    • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
    • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
    • After the stand is removed, replace the stand with a new one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
yousef aljeemaz
1.066 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G9
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 953
