Ana içeriğe geç
Harman Kardon Esquire Mini Front Panel Replacement
Neye ihtiyacın var
  1. Harman Kardon Esquire Mini Front Panel Replacement, Front Panel: adım 1, 1 resimden 1.
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Front Panel Replacement: adım 2, 1 resimden 1.
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
yousef aljeemaz
1.039 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G9
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 706
