Ana içeriğe geç
Harman Kardon Esquire Mini Speaker Replacement
Neye ihtiyacın var
  1. Harman Kardon Esquire Mini Speaker Replacement, Front Panel: adım 1, 1 resimden 1.
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Speaker Replacement: adım 2, 1 resimden 1.
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
  4. Harman Kardon Esquire Mini Speaker Replacement: adım 4, 1 resimden 1.
    • Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
    • Re-do the same steps above for the other speaker to remove it.
  5. Harman Kardon Esquire Mini Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
yousef aljeemaz
1.039 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G9
5 Üyeler
39 Yorum
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Sizino Santos - Yanıt
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Thanks, I need speaker also, where can I buy.
mnyucel@yahoo.com
mnyucel - Yanıt
Hi, I also need to know where could get new replacement speaker.
Thanks
mezafernando23 -
Hi, I also need to know where could I get the replacement speaker.
Thanks
mezafernando23 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 155
Her zaman: 18,956
