Ana içeriğe geç
Harman Kardon Invoke Microphone on/off Button Replacement
Neye ihtiyacın var
  1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: adım 1, 2 resimden 1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: adım 1, 2 resimden 2.
    • Use a metal spudger to remove the rubber bottom.
  2. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: adım 2, 2 resimden 1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: adım 2, 2 resimden 2.
    • Use a Torx #10 screwdriver to remove the four 14.0 mm screws.
  3. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: adım 3, 2 resimden 1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: adım 3, 2 resimden 2.
    • Firmly grip the bottom and wiggle it upwards to remove the base.
  4. Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: adım 4, 2 resimden 1. Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: adım 4, 2 resimden 2.
    • Use a Torx #10 screwdriver to remove three 10.0 mm screws from the highlighted board attached to microphone button.
  5. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: adım 5, 2 resimden 1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: adım 5, 2 resimden 2.
    • Pull the cable lightly to disconnect the button board from device.
    • To replace the microphone button, you will have to replace the entire smaller board.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 583
