Ana içeriğe geç
Harman Kardon Invoke Power Port Replacement
Neye ihtiyacın var
  1. Harman Kardon Invoke Power Port Replacement, Power Port: adım 1, 2 resimden 1. Harman Kardon Invoke Power Port Replacement, Power Port: adım 1, 2 resimden 2.
    • Use a metal spudger to remove the rubber base.
  2. Harman Kardon Invoke Power Port Replacement: adım 2, 2 resimden 1. Harman Kardon Invoke Power Port Replacement: adım 2, 2 resimden 2.
    • Use a T10 Torx screwdriver to remove the four 14 mm screws.
  3. Harman Kardon Invoke Power Port Replacement: adım 3, 2 resimden 1. Harman Kardon Invoke Power Port Replacement: adım 3, 2 resimden 2.
    • Grip the bottom firmly and wiggle upwards to remove it.
  4. Harman Kardon Invoke Power Port Replacement: adım 4, 3 resimden 1. Harman Kardon Invoke Power Port Replacement: adım 4, 3 resimden 2. Harman Kardon Invoke Power Port Replacement: adım 4, 3 resimden 3.
    • Use a T10 Torx screwdriver to remove two 10 mm screws from the board that is attached to the ports.
    • Pull the board up lightly.
  5. Harman Kardon Invoke Power Port Replacement: adım 5, 2 resimden 1. Harman Kardon Invoke Power Port Replacement: adım 5, 2 resimden 2.
    • Pull the cable to disconnect the board from the device.
    • To replacement the service port, you will have to replace the whole board that the port is attached to.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
can I buy that power port circuit board from HK direct?
crokeclan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 493
