Ana içeriğe geç
Harman Kardon Invoke Service Port Replacement
Neye ihtiyacın var
  1. Harman Kardon Invoke Service Port Replacement, Remove the rubber base: adım 1, 2 resimden 1. Harman Kardon Invoke Service Port Replacement, Remove the rubber base: adım 1, 2 resimden 2.
    • Use a metal spudger to remove the rubber bottom.
  2. Harman Kardon Invoke Service Port Replacement, Remove the base screws: adım 2, 2 resimden 1. Harman Kardon Invoke Service Port Replacement, Remove the base screws: adım 2, 2 resimden 2.
    • Use a #10 Torx screwdriver to remove four 14 mm screws.
  3. Harman Kardon Invoke Service Port Replacement, Remove the base: adım 3, 2 resimden 1. Harman Kardon Invoke Service Port Replacement, Remove the base: adım 3, 2 resimden 2.
    • Firmly grip the bottom and wiggle upwards to remove the base.
  4. Harman Kardon Invoke Service Port Replacement, Removing the board: adım 4, 3 resimden 1. Harman Kardon Invoke Service Port Replacement, Removing the board: adım 4, 3 resimden 2. Harman Kardon Invoke Service Port Replacement, Removing the board: adım 4, 3 resimden 3.
    • Use a #10 Torx screwdriver to remove two 10 mm screws from board attached to ports.
    • Pull board up lightly.
  5. Harman Kardon Invoke Service Port Replacement, Disconnect the board: adım 5, 2 resimden 1. Harman Kardon Invoke Service Port Replacement, Disconnect the board: adım 5, 2 resimden 2.
    • Pull cable to disconnect board from device.
    • For replacement of service port, you will have to replace whole board that the port is attached to.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,025
