Ana içeriğe geç
Harman Kardon Invoke Speaker Replacement
Neye ihtiyacın var
  1. Harman Kardon Invoke Speaker Replacement, Speakers: adım 1, 3 resimden 1. Harman Kardon Invoke Speaker Replacement, Speakers: adım 1, 3 resimden 2. Harman Kardon Invoke Speaker Replacement, Speakers: adım 1, 3 resimden 3.
    • Use metal spudger to remove top cover from smart speaker.
    • Use the Phillips #2 screwdriver, remove the three 17mm screws.
  2. Harman Kardon Invoke Speaker Replacement: adım 2, 3 resimden 1. Harman Kardon Invoke Speaker Replacement: adım 2, 3 resimden 2. Harman Kardon Invoke Speaker Replacement: adım 2, 3 resimden 3.
    • Once the 17 mm screws are removed, lift the volume wheel.
    • Lift slowly as you do not want to damage the cable connected to the LED board.
    • Pull lightly on the cable in order to remove both the volume wheel and LED board.
  3. Harman Kardon Invoke Speaker Replacement: adım 3, 3 resimden 1. Harman Kardon Invoke Speaker Replacement: adım 3, 3 resimden 2. Harman Kardon Invoke Speaker Replacement: adım 3, 3 resimden 3.
    • Use the Torx #10 screwdriver, remove the four 14 mm screws around the lid.
    • Remove lid.
  4. Harman Kardon Invoke Speaker Replacement: adım 4, 3 resimden 1. Harman Kardon Invoke Speaker Replacement: adım 4, 3 resimden 2. Harman Kardon Invoke Speaker Replacement: adım 4, 3 resimden 3.
    • Once lid is removed, housing can now slide upwards.
    • Use the Torx #10 screwdriver, remove both 10 mm screws for each speaker that must be replaced.
  5. Harman Kardon Invoke Speaker Replacement: adım 5, 1 resimden 1.
    • Pull on the speaker cables lightly in order to detach the speakers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,271
