Ana içeriğe geç
Harman Kardon Onyx Studio 2 Battery Replacement
Neye ihtiyacın var
  1. Harman Kardon Onyx Studio 2 Battery Replacement, Front Panel: adım 1, 3 resimden 1. Harman Kardon Onyx Studio 2 Battery Replacement, Front Panel: adım 1, 3 resimden 2. Harman Kardon Onyx Studio 2 Battery Replacement, Front Panel: adım 1, 3 resimden 3.
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Battery Replacement: adım 2, 2 resimden 1. Harman Kardon Onyx Studio 2 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Battery Replacement: adım 3, 1 resimden 1.
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Battery Replacement: adım 4, 2 resimden 1. Harman Kardon Onyx Studio 2 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Battery Replacement, Battery: adım 5, 3 resimden 1. Harman Kardon Onyx Studio 2 Battery Replacement, Battery: adım 5, 3 resimden 2. Harman Kardon Onyx Studio 2 Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Begin by removing the three 10.4 mm T10 Torx screws from the battery cover.
    • Remove battery cover.
    • Pull battery out to replace.
Sonuç
45 farklı kişi bu kılavuzu tamamladı.
Alexandra Achtenberg
2.051 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G5
3 Üyeler
24 adet Kılavuz yazıldı
21 Yorum
Thanks for the step by step instructions. I have tried replacing the batteries but the speaker still won't turned on. I believe the battery cable/module is broken, do you know how to fix it? Thanks.
Wompy Pratomo - Yanıt
Can you put a step by step instruction how to replace a battery on a Harman/ Kardon esquire 2?
Bullet Magnet - Yanıt
Hello, what kind of battery is good for replacement? I'm thinking of using LG 3000mAh or Panasonic 3400 mAh (both unprotected) and making a direct swap. Help please
marcel - Yanıt
Can you tell me what kind of the hk onyx speaker battery's, if you can show me step instructions to replace! Thankyou!
happymandm8 - Yanıt
This worked great. Thanks. Battery would not charge. Bought a replacement on Ebay and now it works as if new.
JSM - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 129
Son 30 gün: 488
Her zaman: 89,361
