Ana içeriğe geç
Harman Kardon Onyx Studio 2 Circuit Board Replacement
Neye ihtiyacın var
  1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: adım 1, 3 resimden 1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: adım 1, 3 resimden 2. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: adım 1, 3 resimden 3.
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 2, 2 resimden 1. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 2, 2 resimden 2.
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 3, 1 resimden 1.
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 4, 2 resimden 1. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 4, 2 resimden 2.
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Control Board: adım 5, 1 resimden 1.
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 6, 2 resimden 1. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 6, 2 resimden 2.
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 7, 2 resimden 1. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 7, 2 resimden 2.
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: adım 8, 2 resimden 1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: adım 8, 2 resimden 2.
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 9, 2 resimden 1. Harman Kardon Onyx Studio 2 Circuit Board Replacement: adım 9, 2 resimden 2.
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Alexandra Achtenberg
2.081 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G5
3 Üyeler
24 adet Kılavuz yazıldı
6Kılavuz Yorumları
Where do I get another one
Adrian tlahuel - Yanıt
Where we buy the board?
Eric Therrien - Yanıt
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
markcendan - Yanıt
Where can I Buy a new hk onix studio Main board?
tecnologia en localizaciòn - Yanıt
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Maureen Field - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 123
Her zaman: 22,852
