Ana içeriğe geç
Harman Kardon Onyx Studio 2 Front Panel Replacement
Neye ihtiyacın var
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: adım 1, 3 resimden 1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: adım 1, 3 resimden 2. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: adım 1, 3 resimden 3.
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: adım 2, 2 resimden 1. Harman Kardon Onyx Studio 2 Front Panel Replacement: adım 2, 2 resimden 2.
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: adım 3, 1 resimden 1.
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: adım 4, 2 resimden 1. Harman Kardon Onyx Studio 2 Front Panel Replacement: adım 4, 2 resimden 2.
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
Sonuç
To reassemble, follow these steps in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Alexandra Achtenberg
2.051 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G5
3 Üyeler
24 adet Kılavuz yazıldı
Bir Yorum
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 6,151
