Ana içeriğe geç
Hasbro Bop-It Micro Series Speaker Replacement
Neye ihtiyacın var
  1. Hasbro Bop-It Micro Series Speaker Replacement, Back Case: adım 1, 1 resimden 1.
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Speaker Replacement: adım 3, 1 resimden 1.
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Speaker Replacement, Speaker: adım 4, 2 resimden 1. Hasbro Bop-It Micro Series Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Remove the (3) #3 Phillips head 6 mm screws using your Phillips #0 screwdriver, and remove the plastic with your fingers.
  5. Hasbro Bop-It Micro Series Speaker Replacement: adım 5, 1 resimden 1.
    • De-solder the speaker from the wires. Refer to the soldering guide for instructions on how to solder
Sonuç
Follow the steps of this guide in reverse to reassemble.
2 farklı kişi bu kılavuzu tamamladı.
Glenn Haag
479 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Fall 2016 IUPUI, Team 3-1, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,404
