Ana içeriğe geç
Hasbro Furby 2012 Switch Replacement
Neye ihtiyacın var
  1. Hasbro Furby 2012 Switch Replacement, Outer Shell: adım 1, 3 resimden 1. Hasbro Furby 2012 Switch Replacement, Outer Shell: adım 1, 3 resimden 2. Hasbro Furby 2012 Switch Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
  2. Hasbro Furby 2012 Switch Replacement: adım 2, 3 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 2, 3 resimden 2. Hasbro Furby 2012 Switch Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 driver to unscrew the eight 10mm screws.
    • Remove the base ring after unscrewing all the screws.
    • Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
  3. Hasbro Furby 2012 Switch Replacement: adım 3, 2 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 3, 2 resimden 2.
    • Unhook the white ribbon from the tab on the base.
  4. Hasbro Furby 2012 Switch Replacement: adım 4, 3 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 4, 3 resimden 2. Hasbro Furby 2012 Switch Replacement: adım 4, 3 resimden 3.
    • Roll the Furby's fur downward.
    • Disconnect the now exposed red wire.
  5. Hasbro Furby 2012 Switch Replacement: adım 5, 3 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 5, 3 resimden 2. Hasbro Furby 2012 Switch Replacement: adım 5, 3 resimden 3.
    • Locate the two middle clips first.
    • Locate the two remaining clips on Furby's sides, they are opposite each other.
    • Orient the Furby upside down with the tail facing away from you.
  6. Hasbro Furby 2012 Switch Replacement: adım 6, 3 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 6, 3 resimden 2. Hasbro Furby 2012 Switch Replacement: adım 6, 3 resimden 3.
    • Insert a metal prying tool directly into the clip opening.
    • Press upward into the clip. At the same time, use your other hand to pull away the plastic seam from the Furby's body.
    • Repeat the previous step to remove the remaining three clips.
  7. Hasbro Furby 2012 Switch Replacement: adım 7, 3 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 7, 3 resimden 2. Hasbro Furby 2012 Switch Replacement: adım 7, 3 resimden 3.
    • Locate the two 10mm screws and remove them with the Phillips #0 head screwdriver.
    • Lift up on the fur covering until the face of the Furby is exposed.
  8. Hasbro Furby 2012 Switch Replacement: adım 8, 3 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 8, 3 resimden 2. Hasbro Furby 2012 Switch Replacement: adım 8, 3 resimden 3.
    • Orient the Furby on its side to where the beak is facing left and locate the edge of the aluminum tape.
    • Lift tape gently and peel back until the tape is nearly removed.
    • Do not pull on the yellow wire located on the opposite end of the tape.
  9. Hasbro Furby 2012 Switch Replacement: adım 9, 2 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 9, 2 resimden 2.
    • Locate the four 10mm screws. Two on either side of body, and two on top of back plate, around the tape.
    • Remove the 10mm screws with the Phillips#0 screwdriver.
  10. Hasbro Furby 2012 Switch Replacement: adım 10, 1 resimden 1.
    • Peel the tape gently, grabbing it from the bottom edge and folding the tape upward.
    • Peel the tape up until it is nearly detached from the black case.
  11. Hasbro Furby 2012 Switch Replacement: adım 11, 2 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 11, 2 resimden 2.
    • Orient the Furby face down, with the base facing away from you.
    • Locate the clips below the ears.
    • Repeat the technique used in Step 6. Create leverage using a metal prying tool to press upward into the clip, while also pulling back on the clip itself.
  12. Hasbro Furby 2012 Switch Replacement: adım 12, 2 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 12, 2 resimden 2.
    • Remove the loose, plastic back panel by pulling the panel away from Furby's body.
  13. Hasbro Furby 2012 Switch Replacement, Switch: adım 13, 2 resimden 1. Hasbro Furby 2012 Switch Replacement, Switch: adım 13, 2 resimden 2.
    • Locate and remove the two screws holding in the switch using J0 Phillips Head Screw Driver.
  14. Hasbro Furby 2012 Switch Replacement: adım 14, 2 resimden 1. Hasbro Furby 2012 Switch Replacement: adım 14, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Orient the Furby with the beak facing right.
    • Using the blunt and pointed tweezers, remove the black connector.
    • Insert the new switch in place of where the previous connector was located.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan Castillo
912 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-5, Livingston Fall 2016 Cal Poly, Team 15-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G5
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Did someone find a replacement furby switch? Or found a way to repair the one inside the furby already?
Frubyx - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,368
