Ana içeriğe geç
Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
Neye ihtiyacın var
  1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: adım 1, 3 resimden 1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: adım 1, 3 resimden 2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: adım 1, 3 resimden 3.
    • Find the removable panel at the bottom of the hand.
    • Use your finger to push upwards and open the panel.
    • Slide the panel off and separate it from the hand.
    FixBot'a Sor
    Yorum Ekle
  2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 2, 2 resimden 1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 2, 2 resimden 2.
    • Remove the left-most battery by pushing down on the positive end and pulling it out.
    • Repeat this for the next two batteries.
    FixBot'a Sor
    Yorum Ekle
  3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: adım 3, 1 resimden 1.
    • Remove the screws within the gauntlet and surrounding the palm.
    FixBot'a Sor
    Yorum Ekle
  4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 4, 1 resimden 1.
    • Open the gauntlet carefully, as there are wires connecting both sides.
    • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
    FixBot'a Sor
    Yorum Ekle
  5. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 5, 1 resimden 1.
    • To replace the LED chip, remove the screw holding the chip in place.
    FixBot'a Sor
    Yorum Ekle
  6. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 6, 1 resimden 1.
    • Ensure that the LED chip is in the correct area with the correct polarity.
    • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jessica
109 İtibar
1 Kılavuz yazıldı
Ekip
Marist, Team 1-3, Chaterdon Spring 2023 Marist, Team 1-3, Chaterdon Spring 2023 üyesi
MARS-CHATERDON-S23S1G3
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 676
