Ana içeriğe geç
Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
Neye ihtiyacın var
  1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: adım 1, 3 resimden 1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: adım 1, 3 resimden 2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: adım 1, 3 resimden 3.
    • Find the removable panel at the bottom of the hand.
    • Use your finger to push upwards and open the panel.
    • Slide the panel off and separate it from the hand.
  2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 2, 2 resimden 1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 2, 2 resimden 2.
    • Remove the left-most battery by pushing down on the positive end and pulling it out.
    • Repeat this for the next two batteries.
  3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: adım 3, 1 resimden 1.
    • Remove the screws within the gauntlet and surrounding the palm.
  4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 4, 1 resimden 1.
    • Open the gauntlet carefully, as there are wires connecting both sides.
    • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
  5. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 5, 1 resimden 1.
    • To replace the LED chip, remove the screw holding the chip in place.
  6. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: adım 6, 1 resimden 1.
    • Ensure that the LED chip is in the correct area with the correct polarity.
    • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
Sonuç
Jessica
109 İtibar
1 Kılavuz yazıldı
Ekip
Marist, Team 1-3, Chaterdon Spring 2023 Marist, Team 1-3, Chaterdon Spring 2023 üyesi
MARS-CHATERDON-S23S1G3
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 461
