Giriş
This guide will show you how to replace the Furby's light sensor circuit board.
Neye ihtiyacın var
Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
Remove the 10mm Phillips #0 screw holding the circuit board in.
Gently lift out the circuit board.
Bir başkası bu kılavuzu tamamladı.
