Ana içeriğe geç
Hasee Z7M-i78172D1 Battery Replacement
Neye ihtiyacın var
  1. Hasee Z7M-i78172D1 Battery Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
  2. Hasee Z7M-i78172D1 Battery Replacement: adım 2, 3 resimden 1. Hasee Z7M-i78172D1 Battery Replacement: adım 2, 3 resimden 2. Hasee Z7M-i78172D1 Battery Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to take off the back plastic panel.
  3. Hasee Z7M-i78172D1 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Use a Phillips #0 head screwdriver to remove the four 7mm screws that hold the battery in place.
  4. Hasee Z7M-i78172D1 Battery Replacement: adım 4, 2 resimden 1. Hasee Z7M-i78172D1 Battery Replacement: adım 4, 2 resimden 2.
    • Gently pry off the connecting wires with the plastic opening tool.
  5. Hasee Z7M-i78172D1 Battery Replacement: adım 5, 2 resimden 1. Hasee Z7M-i78172D1 Battery Replacement: adım 5, 2 resimden 2.
    • Lift the battery out.
Sonuç
Desiree Mora
289 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G6, Eyestone Spring 2018 USF Tampa, Team S6-G6, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 431
