Ana içeriğe geç
Hasee Z7M-i78172D1 Graphic Card Fan Replacement
Neye ihtiyacın var
  1. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
  2. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: adım 2, 3 resimden 1. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: adım 2, 3 resimden 2. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to take off the back plastic panel.
  3. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: adım 3, 3 resimden 1. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: adım 3, 3 resimden 2. Hasee Z7M-i78172D1 Graphic Card Fan Replacement, Graphic Card Fan: adım 3, 3 resimden 3.
    • To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable.
  4. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: adım 4, 1 resimden 1.
    • Use a #0 Phillips head screwdriver and unscrew the five 7mm screws holding the fan in place.
  5. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: adım 5, 2 resimden 1. Hasee Z7M-i78172D1 Graphic Card Fan Replacement: adım 5, 2 resimden 2.
    • Lift the Graphics card fan out and replace with the replacement fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zachary Gay
124 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G6, Eyestone Spring 2018 USF Tampa, Team S6-G6, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 397
