Ana içeriğe geç
Hatch Restore Bottom Circuit Board Replacement
Neye ihtiyacın var
  1. Hatch Restore Bottom Circuit Board Replacement, Intro: adım 1, 2 resimden 1. Hatch Restore Bottom Circuit Board Replacement, Intro: adım 1, 2 resimden 2.
    • Replacing your bottom circuit board will be easy.
  2. Hatch Restore Bottom Circuit Board Replacement: adım 2, 2 resimden 1. Hatch Restore Bottom Circuit Board Replacement: adım 2, 2 resimden 2.
    • Peel away the rubber feet.
  3. Hatch Restore Bottom Circuit Board Replacement: adım 3, 2 resimden 1. Hatch Restore Bottom Circuit Board Replacement: adım 3, 2 resimden 2.
    • Remove the indicated 8 screws.
    • You may need to remove some adhesive from the screws to remove them.
  4. Hatch Restore Bottom Circuit Board Replacement: adım 4, 2 resimden 1. Hatch Restore Bottom Circuit Board Replacement: adım 4, 2 resimden 2.
    • Pry off the bottom cover.
  5. Hatch Restore Bottom Circuit Board Replacement: adım 5, 1 resimden 1.
    • Remove the 6 indicated screws.
  6. Hatch Restore Bottom Circuit Board Replacement: adım 6, 2 resimden 1. Hatch Restore Bottom Circuit Board Replacement: adım 6, 2 resimden 2.
    • Remove the power cable
    • There is a ribbon cable under the board. Do not pull the circuit board too far from the device.
  7. Hatch Restore Bottom Circuit Board Replacement: adım 7, 2 resimden 1. Hatch Restore Bottom Circuit Board Replacement: adım 7, 2 resimden 2.
    • Push the black tabs on the ZIF connector towards the cable, then remove the cable.
    • The cable should have no resistance when pulled out. Do not forcefully remove the cable.
Sonuç
9021007
4.656 İtibar
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 525
