Ana içeriğe geç
Havoc Heli IR LED Replacement
Neye ihtiyacın var
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: adım 1, 2 resimden 1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: adım 1, 2 resimden 2.
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
  2. Havoc Heli IR LED  Replacement: adım 2, 3 resimden 1. Havoc Heli IR LED  Replacement: adım 2, 3 resimden 2. Havoc Heli IR LED  Replacement: adım 2, 3 resimden 3.
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
  3. Havoc Heli IR LED  Replacement: adım 3, 3 resimden 1. Havoc Heli IR LED  Replacement: adım 3, 3 resimden 2. Havoc Heli IR LED  Replacement: adım 3, 3 resimden 3.
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
  4. Havoc Heli IR LED  Replacement: adım 4, 1 resimden 1.
    • Lift up the red IR LED cover to remove it.
  5. Havoc Heli IR LED  Replacement: adım 5, 2 resimden 1. Havoc Heli IR LED  Replacement: adım 5, 2 resimden 2.
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
  6. Havoc Heli IR LED  Replacement: adım 6, 2 resimden 1. Havoc Heli IR LED  Replacement: adım 6, 2 resimden 2.
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Kent
128 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 526
