Ana içeriğe geç
Havoc Heli IR LED Replacement
Neye ihtiyacın var
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: adım 1, 2 resimden 1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: adım 1, 2 resimden 2.
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Havoc Heli IR LED  Replacement: adım 2, 3 resimden 1. Havoc Heli IR LED  Replacement: adım 2, 3 resimden 2. Havoc Heli IR LED  Replacement: adım 2, 3 resimden 3.
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
    FixBot'a Sor
    Yorum Ekle
  3. Havoc Heli IR LED  Replacement: adım 3, 3 resimden 1. Havoc Heli IR LED  Replacement: adım 3, 3 resimden 2. Havoc Heli IR LED  Replacement: adım 3, 3 resimden 3.
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
    FixBot'a Sor
    Yorum Ekle
  4. Havoc Heli IR LED  Replacement: adım 4, 1 resimden 1.
    • Lift up the red IR LED cover to remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Havoc Heli IR LED  Replacement: adım 5, 2 resimden 1. Havoc Heli IR LED  Replacement: adım 5, 2 resimden 2.
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
    FixBot'a Sor
    Yorum Ekle
  6. Havoc Heli IR LED  Replacement: adım 6, 2 resimden 1. Havoc Heli IR LED  Replacement: adım 6, 2 resimden 2.
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Kent
128 İtibar
1 Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-13, Lauer Fall 2016 Michigan Tech, Team 1-13, Lauer Fall 2016 üyesi
MTU-LAUER-F16S1G13
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 41
Her zaman: 997
