Ana içeriğe geç
Headlight Bulb Replacement
Neye ihtiyacın var
  1. Headlight Bulb Replacement, Headlight Bulb: adım 1, 1 resimden 1.
    • Before you begin, make sure you have the right bulb. I got this at the local autozone.
    • Do NOT touch the glass of the bulb. The oils from your fingers can drastically reduce the life of the bulb.
    • Vinyl or latex gloves are great if you have them available, but not required.
  2. Headlight Bulb Replacement: adım 2, 2 resimden 1. Headlight Bulb Replacement: adım 2, 2 resimden 2.
    • Press firmly on the plugs clip and pull to remove the power cable from the bulb.
  3. Headlight Bulb Replacement: adım 3, 3 resimden 1. Headlight Bulb Replacement: adım 3, 3 resimden 2. Headlight Bulb Replacement: adım 3, 3 resimden 3.
    • Lift up and remove the metal wire cage holding the bulb in place.
  4. Headlight Bulb Replacement: adım 4, 1 resimden 1.
    • Remove the bulb by pulling it away from the headlight enclosure.
    • Once the old bulb is removed, take your new one and place it in the headlight.
    • Follow the steps in reverse to secure the new bulb in the headlight.
Sonuç
To replace the bulb, follow the steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
Tim Asp
3.905 İtibar
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,434
